Kayteg1
Jun 03, 2016Explorer II
Did you try rebuild the old pump?
West Marine is selling kits for most of them. It will be special order, but arrives fast.
Here is $49 new pump
BTW since the pressure is adjustable, I would lower it.
All the 60psi on 1gpm pump does is draw higher amp to build the pressure when you are NOT using the pump.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
