STBRetired
Dec 23, 2017Explorer
Drew,
Good point. I hadn't taken that into consideration when I thought about the indicator light. Was just thinking about the lights that show when a fuse is blown, but that is full 12V.
Don,
If I measure the voltage at the converter terminals and then at the battery terminals, there is a 1.1V difference when the batteries are low. That has to be due to the length of the wire and possibly some resistance in the disconnect contacts. Can go with a bigger wire if #4 is not sufficient. Using a PD9280 converter.
Don,
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
