pianotuna
Dec 23, 2017Nomad III
Hi LittleBill,
I have to limit my charging to 108 amps out of a possible 125. I do that by limiting the input amps @ 120 volts on the Magnum 3012.
LittleBill wrote:pianotuna wrote:
Even my Magnum charger with rather large wire and a 3 foot run shows voltage drop when the jars are low.
of course they would show lower voltage if the battery's are low, you either charge by current or voltage.
if the charger is maxed out current wise and is limiting the amperage, then the voltage will not rise until the battery's fall under the current being limited. once the voltage limit is reached, current will keep reducing.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
