DrewE
Dec 24, 2017Explorer III
Mex is right. A fuse or whatever is needed at the battery end of a direct converter to battery wire (at least in nearly all cases). The converter is internally current limited by design and generally by fuses too. The battery is not, and can easily produce enough current to be a fire hazard even with a heavy wire.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
