STBRetired
Mar 14, 2018Explorer
UPDATE:
Well, weather finally got decent enough to work on the wiring. I could not use #2 wire as #4 is the largest that will fit in the terminal strip on the converter. Total length was 14 feet for positive wire and 13 feet for negative. The positive is longer to route through the Bussman 100A circuit breaker mounted on the other side of the partition from the battery compartment. Obviously, all wire penetrations through partitions are grommeted. Wires are enclosed in 1" wire loom (that split plastic stuff). Batteries were at 12.5V when I started the voltage loss comparison. Using the original pathway, voltage measured at converter was 14.47. Voltage at batteries was 13.38. switched over to the new path and voltage at converter was 14.47 and voltage at batteries was 14.36. So I went from a 1.09V drop to a 0.11V drop. Granted, I doubt the converter was putting out 80A, but I am happy eliminating 0.98V of loss. Will see how it does when batteries have been discharged further.
If I am still not happy, I can run a second set of #4 from the converter to the battery and breaker. Hopefully that will not be needed.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
