MrWizard
Aug 06, 2018Moderator
you had all the info you needed
crown 235 ampHrs (normally listed at the 20hr rate)
meaning 11.75 amps for 20 hrs, which is a higher rating than 'reserve'
even calculated at 25 amps
6v series-parallel 470ampHrs
are you trying to figure the run time for a 50amp load ?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
