Acampingwewillg's avatar
Acampingwewillg
Explorer II
Apr 30, 2014
Residential fridge
OK....Im sure this topic has Been covered several times but here goes anyway. Just before leaving for a three week trip I discovered the dreaded yellow dis charge at the coils in the fridge compartment.. Unit not cooling. As you can see, I have older Mh with limited space but I found a unit that will fit prerfectly(from another's install of the same unit). I'm getting to the question, this new unit(10.3cf) has exposed rear coils so' I'm assuming exhausting this particular unit would be similar to the heat absorption unit its replacing? I know many of the larger residential units exhaust and vent from the front having interior coils. I want to install whatever vent fans in before placing the fridge into place. Any comments would be appreciated.. Just as a side note, I was very careful with this Dometic ,
only 6 years old before failure....oh well!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
