dougrainer
Jul 10, 2020Nomad
1.It is a RVP(Coleman) basement AC unit. THAT is what they are called
2. Page 57. https://winnebagoind.com/resources/manuals/pdfs/Operator2006/06Journey.pdf
3. MOST Home/residential/Commercial HVAC people have no idea how RV systems operate. They CAN repair most common problems like Capacitor failure and Fan Motor Failures as those are same type systems. I state this because over 41 years I have had to go behind those HVAC repairs and fix the actual problem.
4. They are SEALED units and IF that HVAC person actually knew RV systems could have told you in less than 20 minutes if the unit was charged correctly.
5. One of the BIG scams Home HVAC people do is to ALWAYS state you need to "top off" the Freon or refrigerant system when they come out for that "free" or low cost system check out. Freon 22 costs them about $10 a LB, and they charge it out from $75 to $100 per lb and you ALWAYS need at least 1 to 2 lbs they claim. IF your Home AC unit loses that much in a year you need to have the system checked and any possible leak fixed.
6. IF he knew that, and how to charge a sealed system he would have charged you $100 for a lb of Freon. But since he could not find any Schrader(fill) Valves, he just gave you his standard answer, which is BS.
7. Last, you run the system(BOTH Compressors) for a minimum of 30 minutes and take a Temp corrected AMP draw OF EACH Compressor and that will tell you the state of charge on your system. The DATA plate on the outside Basement unit will have the type coolant(which should be Freon 22 on a 2006 model) and the Amp draw based on 95 degrees ambient. Doug
PS, this may be your system, but verify the Model number.
http://www.rvcomfort.com/pdf_documents/1976323_copy8.pdf
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
