BFL13
Dec 06, 2013Explorer II
Niner , your panels are mono which have (usually it seems) lower Isc per watt than poly, so when you expect (as you should) to get Isc when pointed at a high sun, your expected amps will be a tad less than with a poly.
There may be other virtues with mono that make up for that, don't know.
Poly Isc for 120w panels is approx. 7.6 amps and that is what I got when I had a 120w panel last year for a time.
This has come up several times, especially with those DM mono panels, but not always. There are exceptions where mono = poly for Isc, but seldom seen.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
