jage's avatar
jage
reverse engineer New Model Fan-tastic fan rain sensor?
My old 3-speed, temperature sensing, rain sensing fantastic fan was so great I bought the exact replacement model. The problem is they redesigned the rain sensor. The old model closed with moisture and opened when the sensor dried. In practical terms this meant a light sprinkle might close the fan for 10 minutes, a heavy rain for an hour, at which point the fan opens and if it's still raining it closes again.
Pretty brilliant and my absolute favorite feature of the fan, since it's our only cooling source.
The new fan looks the same except when the slightest bit of moisture gets on the rain sensor it just closes forever. 11pm, 3am, the fan doesn't come on again until you get up and flip the switch (I purposefully and intentionally avoided the remote control).
I emailed fan-tastic about the problem and they basically said "we changed the design".
So now I'm stuck with a brand new, freshly mounted fan-tastic vent that I need to reverse engineer to be like the old one. The worst part is I gave my old fan away because someone with a base model wanted to upgrade the sensors etc.
So- does anyone know how to reverse this design flaw and have it reopen automatically after the sensor dries?
Is there wiring I can change or a component to swap? Which part of the fan controls this behavior? I know I can swap parts with an older model (if I can find one) I just need to know which part/parts to look for.
Obviously if I can soldier, jump or wire something differently that would be easier.
Please let me know any ideas on un-fixing this vent fan!
  • Mine never closed when it rained and co. sent new sensor. Then it closed so fast is was like your warm breath on the sensor. I gave up and put a Max air cover over it and have been satisfied since. some tech we don't need. No more wet bedding.
  • Thanks for all the replies. My fan is above the cab in my van, and the re-designed model is already too tall- it sticks up 2-3" before the cover, whereas the old cover was attached to the flange that goes into the roof.
    However I figured out how to solve all my problems with the new fan (it also seems weak compared to my old one- like you can't tell if it's blowing in or out by feel right next to the fan...)
    In any case the solution is I bought a 6000RBTA "obsolete" model on eBay. It sits flush, has the old black motor and best of all the rain sensor is "broken" so it will open and close and open again!
    Now all I have to do is tear out the otherwise new 803350 and redo my whole install. Good times.
    Thanks again for all the messages and suggestions!
