j-d
Aug 19, 2013Explorer II
Backup lights usually come on anytime the ignintion key is in RUN and the shifter's in R. We have an OP who added a switch to turn them on anytime to provide light to work on the towbar, clever idea.
I'm not about to say This is the Problem This Time, but I can promise you that Loose or Weak Grounds can cause all manner of Gremlins. Try making up a couple temporary grounds. Backup Lamp Bulb Shell to Known Good Ground, and Marker Light Lamp Shell to Known Good Ground. Known Good, like the Chassis.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
