Lakejumper's avatar
Lakejumper
Reverse Polarity code When Plugging in at Home
In the past I have plugged my RV in directly to my 30 receptacle in the garage, without any issues. Today a friend who is visiting plugged into my 30 amp plug, but placed a surge protector in the middle of the power cords and got a Reverse Polarity error code. Why is this happening?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    It could be worse.. When they put in central air at my old sticks and bricks
    The kid hooked the black wire to the green screw. (Hot to ground)
  • Sounds like a good outcome!
    Reverse polarity on an outlet won't harm electronics because it doesn't change the sort of power the device "sees"; it's no different than plugging in an (unpolarized) plug flipped the other way over. Reverse polarity is problematic from a safety standpoint mainly because the hot line is the only one switched by a circuit breaker, so a tripped or shut off breaker doesn't cut off the power if the two are reversed. The normal current path is still broken, of course, so it still protects against a normal overload, but a short circuit to ground would not trip the circuit breaker where the polarity is reversed. If the fault current is sufficient, it would trip the circuit breaker in the house's electric panel where the polarity is correct.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
