ppine's avatar
ppine
Explorer II
May 29, 2017
Reverse Polarity of Batteries
This spring I brought the batteries out of the garage after winter storage and hooked them up to my hybrid trailer. There is a sticker on the front of the trailer indicating the standard red for + and black for - just like a battery charger. Immediately it was obvious something was not right, with massive sparks and the melting of the insulation on the cable between the two batteries.
I looked under the trailer and sure enough the red cable is grounded to the frame. Some of the people that build trailers are ******** or on drugs. Don't assume anything.
Now the charger shuts off and restarts every 10 seconds on shore power. The radio doesn't work. Several lights like the refrigerator don't work. I am thinking about upgrading the charger which is a single stage old Magnetek 6332 and 32 amps. Any thoughts?
  • Always take pics or notes BEFORE disconnecting stuff. Sorry about the welding.
  • Pretty good example of why, if connecting terminals are unknown for polarity, a test with meter will disclose all. I can certainly understand how the OP was mislead by the sticker denoting polarity but I don't trust any sticker or wire schedule color.
    Yes, the older Magnetek converters are lousy, usually a low fixed voltage. If using two 6V batteries in series, a charge voltage of at least 14.8V is good practice. Progressive Dynamics and Iota make a charger with this output voltage.
  • A refrigerator working for 15-years on reversed polarity?
    Here's how it's done...
    Wanted to listen to music with my Lepai amplifier and USB thumbstick last week.
    Enjoying a cup of coffee. No reading glasses. Hooked the Lepai to the lab power supply (REVERSED POLARITY). Hmmmm three point three amps - no music. Turned off the power supply went into the bedroom and snagged my glasses. Came back into the kitchen and had a thoroughly face-reddening Jim Varney moment.
    No one to blame but myself. ---- Happens. At least the misfortune beats getting involved in an auto accident or having a heart attack.
    Instead of pointing fingers I am shopping or a bigger more powerful 12 volt amp.
  • The OP's unit is 15 years old. Hard to believe the supposed MISWIRE went undetected for 15 years. Doug
  • RoyB wrote:
    My converter power distribution panel has two fuses located off to themself labeled REVERSE POLARITY.
    Irrelevant to the OP who says he has an older Magnetek converter which won't have any reverse polarity fuses. If the batteries were hooked up incorrectly the converter is most assuredly toast.
  • RoyB's avatar
    RoyB
    Explorer II
    My converter power distribution panel has two fuses located off to themself labeled REVERSE POLARITY. These two large value ATC fuses are suppose to blow when connected in REVERSE POLARITY to protect things... If you are smoking battery cables then you have bypassed all of this added protection... Sparking battery terminals should have been your first clue something was wrong...
    Two RED ATC 40A fuses shown here
    Google image
    I have had excellent smart mode charging modes using my Progressive Dynamics PD9260C Smart Mode Converter/Charger unit. IOTA also is good multi-stage type converter/charger unit. Check with Randy at BESTCONVERTERS... Using any single mode type converter/charger unit will require you to keep a close eye on your batteries to check for boiling out battery fluids from being over charged using the single 13.6VDC DC output at high amps capacity... When the batteries boil out their fluids and go un-noticed it is usually GAME OVER for the batteries... Would be Lots of $$$ down the drain for me...
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,247 PostsLatest Activity: May 14, 2025
