KD4UPL
Apr 23, 2018Explorer II
You need to find the charging voltages your battery's manufacturer recommends; both bulk and float voltages. They may also have recommendations for maximum charge rate, temperature compensation, length of absorption phase, etc. Then you need to properly program your charge controller to the specs. Just guessing can get you close but may leave you with chronically over or under charged batteries.
Using lots of water normally indicates overcharging or old, worn out batteries.
If your charge controller doesn't allow you to program it specifically for your batteries you may need to invest in a better one that will.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
