time2roll
Apr 23, 2018Nomad
Most 6v GC2 charging specs are 14.4 to 14.8 range. You might be undercharging at 14.1 volts. You might be undercharging at 14.4 volts if the controller drops to float too soon. Need at least two hours of absorption each day when in use and maybe more than six hours. Although 14.1 might be Ok for the aged batteries to reduce water usage until they can be replaced.
I recommend some new new solar closer to 400+ watts considering your usage.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
