HTElectrical
Feb 07, 2012Explorer
CapriRacer wrote:
If you live in a hot climate (AZ, CA, NV, TX, and FL) then the limit is six years. If you live in a cold climate (MN, ND, WI, MT, etc), then the limit is 10 years. States in between are ..... ah ........ in between.
Do you recommend using any tire treatment chemicals if so what and why, if not why? The obvious would be to keep the tires covered, and not park on dirt or wet ground. Anything else to prolong tire life?
Thanks in advance!
Nathan
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
