CapriRacer
Feb 07, 2012Explorer II
daamac wrote:
Is there a 15" LT tire that could replace a 15" Load Range D ST tire?
Not that I am aware of - except there are LT235/75R15 Load Range C's. Perhaps that might work, but you'll have to check to see if there is enough clearance (and the rim width).
Oh and one tidbit I left off - the 40% rule:
If the rim you want to put a tire on is wider (or narrower) than the rim width specified, then the tire's section width is wider (or narrower) by 0.20" for every 1/2" change in rim width.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
