just_me
Feb 14, 2012Explorer
CapriRacer wrote:FastEagle wrote:
....A manufacturer of ST tires says their tires are to be aired to the maximum sidewall pressure at all times. They say they are designed to be aired that way. They are so sure about it that it's a warranty requirement. How can a tire like that be compared to another ST tire who's manufacturer allows air pressure manipulations?
FE
Can we get a link?
I think the only link we have is the tag on the side of the trailer that states info on the trailer and tires (Original) and @PSI required for the weight of the unit. On mine it had "D" rated tires 235/80/16, Bulges developed on the side walls when I called for adjustment, @ about 5K they said the manufacture did not use the right tire load rating and it should have been a "E" and would not stand behind an adjustment. Dealer stepped up and took care of me. Does everyone run there Lt's @ 80psi when not loaded? I don't.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
