Chris3
Feb 20, 2012Explorer
FastEagle wrote:
Michelin commercial tire lineup and an ideal choice for commercial trailers because of low rolling resistance (for better fuel economy), a long-wear tread design and retreadability. These tires also have the strength of a reinforced all-steel construction for lasting durability.
Responsive handling helps you negotiate through tough traffic
Greater durability and puncture
resistance from a third steel belt.
"Easily retreadable all-steel casing
Lowest cost per mile in this category
Resists sidewall damage with the sculptured sidewall protector.
Sidewall: black serrated
outline lettering.
Load Range: E
Service Description: 120/116Q"
The above quote was posted somewhere in this thread. It can not be found in any Michelin publications dated 2010 and later. I read all of them, often.
That's not bashing. It's just getting the playing field even. So correct me if I'm wrong, just post the reference for all to see. I can't post something that I can't find.
ALL LT tires can be used on the RV trailer axles, as long as they conform with the exsisting fitment regulations. I reciently visited a large RV show at Jacksonville, FL. Took lots of pictures and compaired lots of RV trailer tires with the vehicles they were fitted to. The only LT tire found was 16", LRG. At the end of this month I'm going to the RV show here in Greenville, SC. If this thread is still active by then I'll post my findings.
FastEagle
FastEagle
FastEagle, I emailed both Bridgestone and Michelin.
Here is my question and Bridgestone's answer.
Question: "Do you endorse and warranty the Duravis R250 for trailer use? If so what is the warranty period?
Thanks Chris,"
Answer:
"Chris,
Yes, the Duravis R250 is capable of being used on any wheel position, including trailer.
The warranty period is for 5 years or upon wearing down to 2/32nds remaining tread depth, whichever comes first, for workmanship/material.
There is no mileage warranty.
Thank you for the opportunity to be of assistance.
Regards,
Greg McDonald
Engineering Manager Corporate Accounts
Bridgestone America's Tire Operations
615-937-3425"
Note: I will post Michelin's reply when I receive it. Chris
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
