CapriRacer
Feb 21, 2012Explorer II
CapriRacer wrote:I'm back and, yup! I made a mistake - and it has to do with the topic at hand - ST tires vs LT tires.
Opps, I may have made a mistake. I'll get back when I have it figured out.
I went to the Tire and Association Yearbook and listed all the ST tires by size and Load Range - many more than what is available on the market. I then went in the same book and looked up LT tires with the same "size" (meaning the 3 dimensions) and the same Load Range, and compared the load carrying capacities.
Just an FYI, there are mucho, many more LT tires listed in the standards manual than are available in the marketplace. So while there is very little overlap between ST's and LT's that are available for purchase, there is a much better link between these 2 types of tires in the standards manual.
The result? For the same "size" and Load Range, an ST tire carries between 9% and 15% more load than a comparable LT. For the purposes of simplicity, I am going to call this 12%. This is close enough for our purposes.
So using the 12% value in the earlier example, a change from an ST225/75R15 LR D to an LT225/75R16 LR E, the increase in load carrying capacity is 18%, not the figure I quoted earlier.
Sorry for the error.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
