CapriRacer
Feb 21, 2012Explorer II
ExRocketScientist wrote:
This is exactly the information I would like to put in a chart. For all of the LTs that are readily available in the marketplace with a tread appropriate for trailer use (FastEagle would be a big help in coming up with a good list), find out what the load rating is of an ST tire of the same size (even if not available in the marketplace).
Just doing a quick calculation here -- 1.09 x 3042 = 3315 (rounded down to the nearest pound). At 12% that would be 1.12 x 3042 = 3407 pounds. At 13% 1.13 x 3042 = 3437. So it might be that an LT235/75R16 LRE is a direct replacement for a ST235/80R16 LRE (Goodyear Marathon 3420 lb) if the ST235/75R16 LRE is 13% or more than the LT235/75R16 LRE. But it wouldn't be a replacement for the Towmax that FastEagle uses which is 3520 pounds. That is why having accurate numbers here would help.
CapriRacer -- can we work up a chart?
Ah ...... yeah, but why? There are a ton of LT size possibilities, and I'm hoping you're not going to try to cover all of them.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
