CapriRacer
Feb 22, 2012Explorer II
ERS,
How about something like this:
Please note: this was in an Excel spreadsheet that I am just pasting the data without the formatting.
Size Load Range Suggested Replacement Notes Not as good of recommendation, but better than nothing
ST195/75R14 B 185R14C Load Range D - Note: This a VW EuroVan tire that may be hard to locate Use at 40 psi - Be sure to check rim for max pressure Same size, Load Range C - Use the higher inflation pressure = 50 psi, Be sure to check rim for max pressure
ST195/75R14 C 185R14C Load Range D - Note: This a VW EuroVan tire that may be hard to locate Use at 55 psi - Be sure to check rim for max pressure ST205/75R14 Load Range C - Check for clearance - you need 1/8" more between the tire and the trailer body, and 1/4" more between tire tread and fender.
ST205/75R14 B Same size, Load Range C Use 50 psi - Be sure to check rim for max pressure
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
