Tireman9
Feb 23, 2012Explorer
OldGreaser wrote:
Hi FE,
I believe CapriRacer explained this much earlier. My understanding is that a different K factor is used for ST's than for LT's. The LT load rating displayed on the tire is calculated with a greater safety factor and it is possible that an LT marked 3042# could be stronger than an ST marked 3640#.
CapriRacer, please correct me if I am wrong.
Safety Factor is nice sounding in strict engineering terms but Safety Factor involves probability of something bad happening.
The laws that tires must comply with, do not allow 99% or 99.9% or any percentage under 100% being able to pass DOT testing. Any single tire failing to pass the required tests could result in thousands or hundreds of thousands of tires having to be recalled.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
