azjeffh
Feb 28, 2012Explorer
Bus driver Joe wrote:
2001 Komfort 30' Travel trailer w/ 2 slides weighing 10,200lb.... Research verified Load range D rated @ 2450 @ 65psi means I have been overloaded since new. Any history on performance of Maxis?
Joe,
Re: overloaded, remember the tires are not carrying the full 10,200 lbs. My trailer when fully loaded (propane and water included) weighed in at 10,170. However the weight on each tire (weighed individually) was between 1975 and 2025 lbs, the rest was pin weight. I had approx. 8000 lbs on my tires rated to carry 9800 lbs.
After experiencing tread separation on one tire (also a Marathon), I moved "up" to Maxxis 15" LRE's. They lasted 26 months before I experienced sidewall separation on 2 tires within miles of each other.
Most here have had good luck with Maxxis, I just had no luck with them or the other ST manufacturer I purchased from.
Good luck.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
