RayJayco
Mar 02, 2012Explorer
Due to the shape of tires, running over alligators can easily curl up and remove the valve stem, instantly ruining a tire... I have seen and heard this happen on a few occasions...
If you really think about it, it is surprising that it doesn’t happen more often... I try to never run over anything in the road, of course that it not always possible...
CapriRacer, It isn’t that $300 would make the difference in buying a trailer, more so it is not an option that most have the opportunity to review, if you follow...
With the exception of knowledgeable full timers and a few others that are active on forums, most people never give thought to what tires are on a trailer. The same when buying a car, how many people put any thought into what tire is on the car... I believe the mistake (aside from ignorance- in its truest sense) is that people have confidence when they buy a big ticket item such as car, RV and such, that they were engineered and come equipped with proper equipment...
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
