ExRocketScienti
Mar 03, 2012Explorer
OldGreaser wrote:
Thanks for the reference info FE. I've seen debates on whether the axles have to be rated for full GVWR or if pin weight/tongue weight can be excluded. This regulation clarifies that the axles must be rated to meet or exceed the full GVWR. Further details on my rig; it's a 2011 and is in compliance, right down to the yellow color of the weight sticker. Axles are rated 6,000 lbs, so the combination of 3 matches GVWR. Original tires were ST235x80-16R stamped with load rating of 3420 lbs @ 80 psi, so axle/GVWR is covered. We always dump tanks when we travel, except for carrying 5-10 gallons plus ice cubes in the black tank for pyramid attack.
How do they come up with GVWR? That's a good question. With 6k axles being a common selection, they could have worked to that basis for 18k. However, 7k axles are readily available. If nothing else in the design were changed, could the trailer then be 'declared' as 21k, or is detailed analysis of frame & other construction details done? Or, is it a marketing decision based on available tow vehicles which then leads to the axle selection and other details?
I would not assume that a retrofit of 7k axles would allow me to add another 3,000 lbs to the CCC.
As I stated earlier, I had been looking at the Everlite 29FK. Back about a year ago, I noticed an almost 1000 lb drop in the stated GVWR from the previous model year. I contacted them and asked what prompted the change. They said they had been using the sum of the GAWR for the two axles plus the tongue weight, but their engineers had gone back and reviewed all of the designs and made adjustments. I'm sure other manufacturers have had to evaluate their units from an engineering standpoint also.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
