FastEagle
Mar 03, 2012Explorer
NHIrish wrote:
Not sure this is accurate...I always thought the dual rating meant as in a dually setup????? Why would load rating vary on a vehicle with two axles over a vehicle with one axle. This would effectively mean, for my application, that there are NO G rated tires I can find in 16" that would be suitable for use on my 7000 lb axles...which I have 2 of. Just does not make sense to me.
When a little math is used to see what a safe load capacity would be for LRG G614 tires on two 7000# axles using the recommended 12% reduction by GY you are good to go at 13200# GAW. That’s with all tires aired to 110 psi.
FE
On Edit: Remember, that is a tire manufacturer's recommendation and they are not responsible for setting vehicle tire pressures, the vehicle manufacturer is.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
