FastEagle
Mar 04, 2012Explorer
Francesca Knowles wrote:
Sorry if this is redundant...Can/will you post a link to the regs you snip from above?
“S4.2.2.2 When passenger car tires are installed on an MPV, truck, bus, or trailer, each tire's load rating is reduced by dividing it by 1.10 before determining, under S4.2.2.1, the sum of the maximum load ratings of the tires fitted to an axle.”
That rule is always a normal part of the SOP for vehicle manufacturers and has already been accounted for on the vehicle tire placards whenever applicable.
FE
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
