ExRocketScienti
Mar 06, 2012Explorer
CapriRacer wrote:FastEagle wrote:
I do a lot of research. But just for you I went and downloaded the newest information for belts on popular tires. Michelin has the newest data book - May 2011 - and they still have the third belt on their commercial grade 16” truck tires.......
First, commercial grade LT tires aren't the popular tires.
The popular LT's have 2 polyester body plies and 2 steel belts - and may have a nylon cap ply (or 2). A nylon cap ply is a circumferential ply that restricts the growth of the tire at high speeds. Inessence it raises the speed rating of a tire.
All steel - that is, tires with steel body plies and commonly referred to as commercial grade - also have 2 steel belts, plus sometimes a third protector belt. This third belt is not like the nylon cap ply. That steel belt is at a lesser angle to the "working" belts and provides a layer of protection against penetrating objects. The less damage to steel belts, the less likely they are to fail - and this is more true for tires with higher loadings.FastEagle wrote:
.....Maxxis has changed their data book to include a nylon cap vice a third steel belt. (I wonder if they had problems)?......
Like I said before, nylon cap plies serve a different purpose than a third steel belt. I really, really doubt that Maxxis made that change. If anything, they added a nylon cap ply where there wasn't one before.
Oh, and they can add a nylon cap ply to tires with 3 steel belts and it has the same effect.
Not all LT tires billed as "commercial" have the all steel carcass. Two I can mention off hand are the BF Goodrich Commercial T/A (BFGCTA) and the Maxxis UE168 Bravo. For trailer use, the commercial tires are popular, with the Michelin XPS Rib and BFGCTA leading the pack.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
