FastEagle
Mar 07, 2012Explorer
Tireman9 wrote:
What is needed is pictures of placards of TT along with the stated load capacity showing minimal reserve load for the tires. Also clear, in-focus pictures of tire failures. Information on actual loading of tires, not guesses or total trailer weights.
The tires on the trailer for this placard were TowMax ST235/80R16E Rated at 3520# at 80 psi.
This manufacturer has not derated the 7000# axles and has met their minimum requirement with the OE tires. I would guess this trailer fully loaded and nicely balanced will have a pin weight in the 3000# range. That leaves about 12% reserve load capacity above maximum GAW for the OE tires. Much better than other manufacturers of trailers in the same weight class.
Tire Info
FastEagle
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
