kedanie
Mar 16, 2012Explorer II
FastEagle wrote:
:Z
FE
So, rather than address the elephant in the room, you choose to run away and hide?
OK, I'll ask it again.
OK Calvin, one more time. We cannot continue to ignore the elephant in the room. All the other tire company insiders here don't hide anything. Wear as with you there is always that question as to where your true loyalties lie.
Are you or are you not receiving compensation from tire companies of any kind or nationality? A simple yes or no will do. Keep in mind that a non answer is essentially a yes answer.
It is beyond belief that anyone that has had as many tire issues with ST tires as you would continue to blindly use them without some sort of compensation. Most here with any common sense would have looked for an alternative a long time ago instead of filling landfills with your discarded tires.
So, it is up to you.
Keith
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
