CapriRacer
Mar 19, 2012Explorer II
winkyb wrote:ol Bombero-JC wrote:
2) Use LT's? Only applicable for the 16".
Why??:@
Why would you say this I just installed LT`s in 15 inch rims that are rated at 2470 pounds at 106 MPH at 65 pounds PSI.I know ST`s are rated at 2540 pounds and these are rated at 2470.But not as worried about that as much as I am made in China and rated at 65 MPH.Time will tell.If you are with in 280 pounds of the load on 4 tires you better do something else any way.
First, you did not install "LT"'s. You installed "C"'s.
Second, you had a specific thing that you did that works in your case and your case only. It is NOT universal. There are other situations where this doesn't work.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
