winkyb
Mar 22, 2012Explorer
Tireman9 wrote:winkyb wrote:
Tireman I would have said under inflation or over loading.As the side wall damage is the same all the way around.I think most of the time if it is a defect in the tire the damage will be more in one part of the tire.I learned that from Firestone years ago when I had five out of eight go bad on a van and a truck.When they would blow it wound be about a nine inch blow out from bead to bead.One was at 75 MPH but you could still see where the failed area was.
Yes there was a recall on tires in that factory.It was traced to workmanship.If They had a air bubble in the rubber they were takeing a ice pick and letting the air out of the bubble in place of rejecting it.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
