Chris3
Mar 22, 2012Explorer
So how does one explain that people report multiple ST failures, then switched to LT tires and report tire failures ceased?
Is that they switch to a tire type that stands up to road hazards and impact damage better. Does the extra "meat" make the difference?
Is that why the Maxxis and old Denman get better user reports? Both are much heavier tires than the bunch of 35 pounders.
And is that why going to the all steel ply tires like the Michelin XPS RIB and Bridgestone Duravis R250 is even another step up the ladder of putting tire failures behind you? We just do not see reports of these two failing in trailer use and are very common in commercial use on 6K axles.
Road hazards and impact damage may be the achilles heal of most ST tires!
Chris
Chris
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
