FastEagle
Mar 22, 2012Explorer
ExRocketScientist wrote:
I think I may understand what FE is refering to, but I need a confirmation. Bear with me please:
My daughter is learning to drive. We practice parking a lot. There are some parking lots with a lot of my sidewalls left on the curbs. You can see the scuff marks on the sides of my tires -- but it also leaves white concrete residue on my sidewalls. When I was running Goodyear Marathons on the fiver, I would get similar scuff marks, but they would be all the way around the entire circumference of the tire but not in a position where they would be if it were curb contact. It would be from the edge of the tread to about 1" around the sidewall toward the bead. There would also not be any concrete dust sticking to this.
Is this the scrubbing action that FE is talking about?
Or was that perhaps from traveling on gravel roads?
The axle spacing on our dual axle trailer is 33”. When on concrete or asphalt surfaces the tires on the trailer will start leaving a black streak of rubber right in the pavement when the degree of turn gets around 30 degrees. When the degree of turn gets beyond 45 degrees it becomes possible to go and pick-up small chunks of rubber that has ground off the tires during the turn. That’s the kind of tire scrubbing I’m talking about.
FastEagle
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
