Tireman9
Mar 30, 2012Explorer
Supreme Oppressor wrote:
What standards do the manufacturer actually use? GVWR minus 25% pin weight divided by number of tires? I saw a placard like that once but can't seem to find the thread in question. Do they/are they required to weigh side to side? It seems unlikely that it would be the same, especially with so many different floor plans available.
A couple questions, hopefully related to this thread. I saw on most manufacturers websites that a tire once repaired becomes a non-speed rated tire. No description of what that means - how fast can I go on a non-speed rated tire?
Keep up with the failure analysis descriptions. If there is a document describing what to look for in a failure, that would be educational as well. Tread wear ones are commonly available.
I for one am getting a lot out of this and other technical debates on this forum and hope they continue.
RE tire failure analysis. If you go to my blog and work your way through from the first posting you will build what I think will be a better than average understanding of what a tire is and why they fail. I have a number of close-up pictures of actual failures and their cause.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
