JBarca
Apr 02, 2012Nomad II
CapriRacer and Tireman9,
Thank you for taking the time to explain the complexity of what is thought to be a simple question about tire age. It is much appreciated.
The manufactures of ST tires sort of hint to a possible life in their warranty. I have not seen every warranty but it seems that 5 years is found often as a tire warranty. Some slightly more some less. Weather checking seems to come up as 4 years or is not mentioned but the warranty stops at 5 years.
FE found this link for me that I could not find. On page 14 it states 1/16" (2/32") is the max depth of a side wall crack and then it needs to be replaced. This is the 1st I myself have seen a rating. It did not mentioned thread cracks with is what showed up in my last 2 sets of Maxxis ST radials at year 4.5
While we do not yet have a simple answer to when a trailer tires should be replaced, we at least understand the situation better.
For me and towing mainly in Ohio, it appears the 5 year thought is about the expected life. If you get 6 or 7 years it may be luck. The damage to the camper from a blow out can be often times be worse then tire which you need to buy anyway. Since I deal with machinery for a living and believe in Preventive Maintenance programs for wear components, why shouldn't a tire be any different then a brake lining, oil change or any other consumable wear parts. Replace them before the fail.
Thanks again.
John
FastEagle wrote:JBarca wrote:
Ex, Can you find the warranty on line? I look today and could not find it that I knew for sure it was for ST trailer tires. I wanted to see what they say about "weather checking". Some tire companies mention it and some do not.
Page 19
Thanks again.
John
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
