FastEagle
Apr 18, 2012Explorer
CapriRacer wrote:ExRocketScientist wrote:allen8106 wrote:
Copied from Goodyear bulletin PSB #2011-13 dated May 18, 2011
Many trailer manufactures establish the recommended tire inflation pressure based on the 65 mph (104 km/h) rated speed for ST tires. In these cases, the ST tires should be inflated 10 psi (69 kPa) higher than the trailer placard for speeds up to 75 mph (121 km/h) (wheel must be rated for this higher inflation pressure). If the trailer manufacturer’s placard specifically states that the cold inflation pressure is suitable for speeds above 65 mph (104 km/h), no additional inflation pressure adjustment is required.
But then again, there is the issue of exceeding the max inflation pressure listed on the sidewall of the tire. Most of the time the trailer manufacturer already has you inflating to the maximum pressure anyway -- so this is a help to virtually no one.
Just an FYI: In the world of tires, there are exceptions to the rules, and this is one of them. Besides, if you look at the sidewall of an ST tire, it will say "Max Load XXXX at YY psi". That is NOT a statement for a maximum pressure, but it is a statement for maximum load.
In the world of government regulations "recommended tire pressure" is the "correct" tire pressure. Therefore, the tire placard/certification label depicts the correct tire pressure. So, the vehicle manufacturer cannot be held accountable for any GY tire failures when the tire pressure has been increased for speed. Maybe that's why GY is so prompt in paying for vehicle damages. And, remember, Carlisle only recommends 60 MPH for their radial ST tires. Would it be wise to go beyond that when Carlisle will not warrantee them once it’s determined excess speed contributed to a failed Carlisle tire?
Bottom line...Those of us that do not have access to industry standards should leave such things to the vehicle manufacturers to sort out and depict on the vehicles and in their individual vehicle owner's manuals. After all, They built it.
FastEagle
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
