FastEagle
Apr 22, 2012Explorer
Tireman9 wrote:FastEagle wrote:
A question for our experts:
There have been numerous failures from day one with the ground-up LT235/85R16G tires designed for trailer service. They are almost exclusively used on 7000# axles and should have the load capacity to live out their expected life expectancy but are falling short of it. The leading manufacturer has made at least one major attempt at resolving the problem with limited success.
What do you guys think about that steel cased tire? I’ve wondered about it’s regrooveability feature. Even though it has shallow threads it still has the extra tread depth to allow regrooving. Is that presenting a heat problem when the tire is near it’s operational limits? Do you think regrooving them early would help in extending their life expectancy?
FastEagle
I covered Retread and Regroove in my blog.
The heat comes from the area at the edge of the steel belts so cutting parts of the tread will not reduce the amount of rubber between the tread surface and the belts. Also regroving will leave microscopic cuts in the base of the cuts which could lead to accelerated cut growth.
I can't see that you answered anything I asked.
FE
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
