Woodtroll's avatar
Woodtroll
Rewiring Trailer Brakes - How to Allow for Axle Movement?
Hello, folks,
I am planning to rewire my travel trailer axle brakes using a 12/2 commercial brake wire such as this:
https://www.nassaunationalcable.com/12-gauge-2-conductor-duplex-brake-cable.html
I'm going to run a separate wire from a junction at the front of the trailer to each hub. Two axles means four hubs, so there are eight flex points in the wire (frame and axle on each wire) that will be moving constantly. I know that stranded wire is much better at handling flexion, but what else can I do at the point where the wire leaves the trailer frame to help ensure that the wire won't eventually break? Are there any "best practices" that would apply to this installation?
Many thanks!
Regan
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 10, 2026
