Skibane
Oct 24, 2021Explorer II
Don't overlook the wall-mounted thermostat wires. You might try temporarily disconnecting them from the furnace to see if the problem goes away.
Chokes work OK sometimes, but ordinary bypass capacitors (0.1 uF) can also be effective. They're also much cheaper ( which means that you can install a lot more of them), and will fit in much tighter spaces, too.
