Artum_Snowbird
Mar 17, 2015Explorer
enblethen wrote:
I would check your connector to the TV on the trailers umbilical cord. You may find corrosion between the 12 volt line and the right "brake" light.
The other place other than wiring is the junction box where the umbilical cord connects to the trailer wiring.
I agree with this diagnosis. The 12 volt feed is right next to the right turn/brake feed. LED's take so little current that the opportunity to sneak across if the insulation breaks down is quite likely.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
