enblethen
Jul 26, 2020Nomad
Sounds like low voltage through the fuel pump relay. Not sure if yours has one. earlier models do. initial power was fed via the starter relay, then when oil pressure is seen, the fuel pump was energized by oil pressure sending unit.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
