dougrainer
Jul 30, 2016Nomad
There is nothing in the walls or anything else. BEFORE you replaced parts, you should have wired the 120 element direct to 120 for 24 hours. If the freezer did not get blow 10 degrees and the refer below 40 degrees, you have a BAD cooling unit. From what you stated, you have a blocked Cooling Unit. Doug
