BoonHauler
Jan 11, 2015Explorer
MrWizard wrote:
avg working voltage is 30v
avg amps 9a
avg output using PWM 126w (14v*9a) i said avg not max, which might bust 130w
you will need an MPPT controller to really use any of those panels
or
multiple panels of a lower wattage if you want to spend less on the controller
Mr. Wizard:
Yes, as I mentioned I'm already in the MPPT camp with one TS-MPPT-60 already installed. Since then I've decided to double the capacity of my system so I'll be installing a second MS CC. I'll be running with three paralleled panels per Charge Controller.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
