Almot
Jan 31, 2014Explorer III
mena661 wrote:
I was perusing the Rogue 20A manual and saw the 320W limit for 12V systems. I'm wanting to put two 150W panels in series to up the volts and reduce current in an attempt to be able to use more panels on the controller at a later date. If my total amps is well under 20, can I go beyond the 320W max for the controller?
You can, and you should. What you should also do, is get Rogue 30 instead of 20, especially if you go beyond 320W :)...
Rogue 20 will clip the output amps at 20, maybe 21A.
300W array under ideal conditions will output about 10A @30V. After the conversion to 13.5V, 10A becomes 22A. Ideal conditions don't happen at sea level, so you are OK with Rogue 20, but pretty close to losing some power. If you increase the wattage beyond 300 or 320, you will likely lose some power at peak sun (compared to if it were Rogue 30), but you will still get more power than with 320W, because most of the day there will be no clipping as your amps will be below 20.
Rogue 20 requires data converter or remote display to change any settings because it has no interface display like Rogue 30. So the difference in price is not that big.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
