NinerBikes
Aug 29, 2015Explorer
Salvo wrote:
Here I though I was done with this topic.
The worst case scenario for any PS is turning it into an oscillator. I'm not saying that's the case there, but after the mod, the PS should be tested for oscillator tendencies. After all, the cable is connected to the most sensitive area within the PS.
You can minimize noise injection by limiting the cable length to <1.5" and using a bracket to mount the pot. Now there's no human body contact with the cable.
If there is oscillation, it's most likely not going to affect the battery as it is a huge capacitor. Perhaps you now have a "pulse charger". The oscillations may however exceed the limits of some of the components within the PS. That would be the primary concern.
Before doing anything further, I would test the output (unloaded) with a scope (ac setting, 200 mV/div). If the trace is flat, even when grabbing the cable or pot, then no further work in required.
Another potential problem is if one of the pot cables breaks off. What happens to the output voltage? Does it go to zero volts or does it go sky high? Or is it limited to a safe value? If it goes high you'll hear the output caps go pop. The PS reliability definitely decreased with the added pot. Mounting the pot to a bracket will help a lot.
The pot, in this case is most likely set it and forget it. The pot will be mounted to the case with a roughed up surface on the case and on the bottom of the pot, with some Shoe Goo. It will be permanently attached.
I baby my equipment, the possibility of failure at a solder joint is none to none. If you disconnect the continuity of this circuit due to a broken circuit, the voltage drops, if you complete the circuit with no resistance, the voltage goes to 15.66V or thereabouts. With the circuit broken, what do you think is going to happen to DC input? It goes to nothing, or not?
I am about to head out on a 2 week trip, and SCV has bigger fish to fry right now with the wife's AC in her car being down, it being the weekend, and the temps being triple digits down here, so, if you are really curious and can't wait, get a MegaWatt, mod it yourself and find out for us.... otherwise some patience is in order, and that's if SCVjeff doesn't have a lot of better things to do with what limited spare time he has. He did this for me as a big favor, I don't want my posting up of the favor he gave me becoming a pizzing contest between a couple of EE guys, so if you have questions, PM each other, or not, if out of respect for each other.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
