NinerBikes's avatar
NinerBikes
Rogue MegaWatt 30Amp bulk charger.
Been using my Megawatt 30 amp PSU now for over a year with the fine adjust pot, when mxwanderer suggested a 500 ohm 2 watt 10 screw potientiometer to replace the rather touchy one screw micro pot.
Not having the means to solder the new 500ohm 10 screw $6 Bourne pot in place With micromeasure counter on top, I sought the services of a ham radio guru, who also happens to build antenna's for digital TV stations, for a living. Namely SCVJeff, as we've met and camped together at Quartzsite, and in general, the guy plays with electronic stuff that would make my head spin, so a solder job for him was child's play.
Since he was curious, we measured the micro pot on the unit as a 900 ohm resistance unit. Replacement was a 500 ohm unit.
This is the voltage range now with the 500 ohm unit.
Circuit board from a Megawatt S-350-12
Top side.
Finished, haven't decided how I will attach yet the new 10 screw pot, but numerical locking dial settings will make voltage output repeatable.
Another view.
Note the zip ties, extensive use of heat shrink wrap and professional grade quality of all the connections. The heat transfer paste from the factory was, at best, marginal. Jeff made sure to use the good stuff, and in generous quantity, to get the heat out of the electronics, and transferred to the external aluminum case.
BTW, it took 4 pair of hands to remove the circuit board out of the chassis, it is a tight fit.
I'd like to express a deep level of gratitude and thanks to SCVJeff for helping this old hack carpenter that's only ever worked pretty much with 120V and 240V with some minute, clean circuit board soldering repair and replace, since I don't own the tools or knowledge to do work at this level. Special thanks is also due to mexicowanderer, who first found this PSU, saw the fit to dry campers or off the grid campers needs, and used my money and me as the successful guinea pig to even attempt this Rogue venture. I find it some of the best money spent by me for doing exactly what I need in a bulk charging timed battery charger. It will be effortless for me to dial in the exact 13.50 + -.02V I need now for my exotic Telecom 158 AH AGM battery, and it's exotic voltage needs for properly recharging.
If you are in the same boat as me, there is probably none better that an old hand Ham Radio operator or pro to touch soldering on your circuit boards without botching the job. BTW, the Bourne pot terminals needed some serious scraping and cleaning up to get the solder to adhere to them. When it comes to electronics and circuit boards, it's not worth it to cut corners, do it right, the first time. His attention to detail, and having all the tools there to measure, a variac, Fluke DMM, copper weave for wicking solder off the old pot and off the circuit board, cleaning up terminals before resoldering, tie wraps, heat shrink, etc, etc is what is the sign of a person that takes pride in their craftsmenship.
I hope this helps some of you that are on the fence about building your own 14.8V MANUAL timed bulk charger for your dry camping applications off the grid.
  • I dood a little research afore recommending the .5K pottie
    But I need '59 Caddie fins on the case and a wind-tunnel blower inside before the BORG is finished. Not kidding about the fan -40- watts 120vac. Aim it downward and the BORG would become a hovercraft. Those Megawatts ain't gonna overheat those power transistors. I have to deal with the Schottky rectifiers sucking another .25 volt off the scale but I have a 25-amp DC\DC booster ready to whip the wogs up to 80-volts if I need to. Like equalize 5-6-cell batteries in series if I want to.
    All of the GDT, MOVs, TVS diodes will be here next week. The 2-pole 6-position 20-amp switch with the rooster beak knob is surplus aerospace. Gold contacts. Wheeeee...this gonna be fun. But the hovercraft fan resides in Florida. I wanna see that needle on that analog meter on its back at the three o'clock position. What? A boondocker buttkicker?
    analog
  • SCVJeff wrote:
    Geeeeze..... Someone call Housekeeping and clean up that bench
    Hey, we found everything, there aren't any screws missing, not like it vibrates or needs any blue loctite on the fasteners. Now about those new LED's and dimmers...
    BTW, I must admit, there is a very imperceptible fine line between a Ham Shack and a work bench, which, to the untrained eye, has all the same darn tools on it most of the time, shared in common.
  • Geeeeze..... Someone call Housekeeping and clean up that bench
  • Very nice job there niner. I have to admit that the megawatt is the cats meow I needed for taking care of the lifelines off of solar. Someday I may go the new pot route but till then a offset screw driver takes the sensitivity out of the original.
  • Sounds like you have a great project, and this will be helpful to others wanting to adjust their voltage upward!
    As for me, I have a Trace M1512 inverter/charger with max 70 amp output. I fid that if over 45 amps, then the cooling fan must run, and that the battery can get warm if I am charging over 50 amps! Not wanting the battery to heat to much, I keep mine at about 50% max charge rate. Actually I normally let my 400 watt solar panels do the charging!
    This will work great to quickly charge a dead car battery. Just be careful - in that 14.8 volts will quickly start to boil away water once the battery is full, and overcharging.
    I met Jeff many years ago when he was working for a TV station, and I was working on their antique air conditioners in 1985. He is a great guy, I saw him again in Quartzsite about 10 years ago. I was new to repairing HAVC back in 85. I would probably do a much better job of repairing that stuff now.
    Good luck,
    Fred.
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 21, 2025
