mlts22's avatar
mlts22
Explorer II
May 05, 2016
Roll up solar panels for portability?
At a faire I frequent, one person had three 20 foot long roll-up solar panels, similar to this.
I wonder if anyone has any recommendations for panels that are more durable, and designed for more setup and takedown cycles? This would be useful for boondocking.
  • I always thought the rolls would make a good portable as long as rolling and unrolling wouldn't hurt them.
  • pianotuna wrote:
    Hi
    Unisolar panels are not really designed to be portable in the sense of unrolling and rerolling repeatedly. They were intended for use on a metal roof.
    I love my US-64 Unisolar panels because of the blocking diodes between each and every cell. I get great low light results.
    I think this is the use these panels were designed for. If you were to get this panel, you'd be looking to roll out a 18 foot panel.
    Regards,
    Doug
  • Hi
  • Almot's avatar
    Almot
    Explorer III
    OP asked about portable.
    It rolls up compact, but I'm not sure how well it will take repeated rolling-unrolling. Without some sort of rigid backing you would have to lay it down on the ground, this doesn't sound good.
    I read that amorphous panels work more efficiently than crystalline panels in low-light conditions - more amps per nominal wattage. But in full sun 130W is still 130W.
    With 24V panel you will need MPPT, and the cheapest half-decent one is ~$150.
  • agesilaus wrote:
    Amorphous panels are always less efficient. But the no drill installation is very tempting. And less efficient does not always mean not efficient enough for your purpose.
    For reference the linked panel cost $1.78/W and uses 23.3 sq ft.
    2 80W panels on Solar Blvd cost $1.00/W and uses 12.3 sq ft but they don't roll up. S&H should be considered.
  • CA Traveler wrote:
    Generally those panels are more $ with less output. Most just use the standard solid 12V panels.
    Several people in the comments and answers to questions report having them on their RV. My major concern would be that the adhesive is not strong enough to withstand 60 mph winds generated running down the road. But I didn't see any complaints.
  • Generally those panels are more $ with less output. Most just use the standard solid 12V panels.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
