SJ-Chris
Jul 17, 2018Explorer II
Update: I tried my heavier duty extension cord. It has a tag which says it is rated for 15amps (and it is certainly thicker than the other extension cord I was using). It doesn't have a gauge indicated on it though. I believe it also might be 25 feet shorter than my other extension cord.
I plugged it in and turned on the AC. After sitting in the RV for about 30 minutes it seemed to work exactly as expected. I will let it run for another hour and see if all appears well. If so, I think I'm back in good shape and with your help solved yet another issue.
RVs seem to be a never ending learning opportunity! :-)
Thanks again all!
Chris
Thanks again all!
Chris
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
